DWG file is not displayed
Ludek
Post by Ludek » Tue Aug 11, 2020 3:43 pm
I have troubles with opening some dwg files. It tells me "loaded sucessfully", it can also recognize the autocad format:
Drawing loaded successfully: X:/F-20-03-00.dwg
Format: R15 (2000) DWG Drawing (OpenDesign) (*.dwg)
But nothing is displayed on the screen. Is there advice how to solve it? Converting to other older / newer / dwg / dxf format does not help.
Thanks, Ludek.
F-20-03-00.dwg
(262.79 KiB) Downloaded 304 times
Ludek
Re: DWG file is not displayed
Post by Ludek » Tue Aug 11, 2020 3:49 pm
QCAD version: 3.24.3.0 (3.24.3)
Operating system: WIN 7, 64
Post by andrew » Tue Aug 11, 2020 4:44 pm
The entire drawing was created in a layout block (unusual, but no problem).
- View > Block List
- Double-click on "Layout 1"
Ludek
Post by Ludek » Wed Aug 12, 2020 9:59 am
Thanks a lot for the hint. It works!
Ludek.
