I recently purchased QCAD/CAM. I have 2 computers with macOS and Arch Linux installed. I successfully installed on macOS but on Arch Linux, actually on Wayland session type it won't launch. I did see first launch screen with some configurations like metric system etc.. but after that it's just nothing happening. I'm using the latest version of qcadcam-3.24.3-pro-linux-qt5.13-x86_64.run file from mail link and
my system specs:
Running qcad from /opt/qcadcam-3.24.3-pro-linux-qt5.13-x86_64/qcad outputs:Kernel: 5.7.12-arch1-1
WM: sway
CPU: AMD Ryzen 5 2600 (12) @ 3.850GHz
GPU: AMD ATI Radeon RX 5600 OEM/5600 XT / 5700/5700 XT
Memory: 2302MiB / 16005MiB
QT5:QCAD version 3.24.3
Warning: Could not find the Qt platform plugin "wayland" in ""
Fatal: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: linuxfb, minimal, offscreen, xcb.
./qcad: line 9: 9062 Aborted (core dumped) LD_LIBRARY_PATH="$DIR" "$binary" "$@"
QCAD has unexpectedly quit.
Please use the offscreen platform plugin for headless systems
(without a running X11 server):
./qcad -platform offscreen
In addition, you might have to override the default Qt style
to prevent the loading of a native desktop style (such as GTK):
./qcad -style plastique
Wayland specific env settings:Qt 5.15.0 (x86_64-little_endian-lp64 shared (dynamic) release build; by GCC 10.1.0) on "wayland"
export RADV_PERFTEST=aco
export QT_QPA_PLATFORM=wayland
export GDK_BACKEND=wayland
export XDG_SESSION_TYPE=wayland
export mesa_glthread=true
