Lines and curves change, compatibility/polylines?
Gurr
Post by Gurr » Tue Jul 28, 2020 1:39 am
Hey folks! I'll also be searching for this problem in the meantime, but its a little tough to figure out how to phrase it so I'll also post it.
I'm using a silhouette cutter (with their software silhouette studio) to make cutouts of designs. When I take the dxf I've made and import it into the silhouette studio, the lines come in curved.
I had this same issue with NanoCAD before and I managed to fix it through joining lines to make a single polyline. Unfortunately, QCAD isn't letting me do so.
Any thoughts? File included. Here's a pic of what I'm talking about as well.
troubleshooting file.dxf
(226.83 KiB) Downloaded 303 times
Re: Lines and curves change, compatibility/polylines?
Post by CVH » Tue Jul 28, 2020 8:16 am
The outcome has too much or no bulgings.
I suspect the problems ly with silhouette studio.
Now, the contour is a logical closed poly with a continuous pattern in a block.
A) Does it look different when the source is not in a block?
My CNC doesn't like the polyline pattern setting.
B) Any change with the setting turned off?
C) Any change if the poly would be geometrically closed?
Just some ideas :wink:
Gurr
Post by Gurr » Tue Jul 28, 2020 10:36 pm
Thanks for the response!
It ended up being a polyline issue. It was resolved when I exploded the part instead of having it as one.
Post by CVH » Wed Jul 29, 2020 2:03 am
The solution was 'joining lines to make a single polyline'
The problem was 'Unfortunately, QCAD isn't letting me do so.'
While it was a polyline in QCAD.
And the solution is splitting up the Poly.
All this doesn't make sense anymore!
