QCAD Freezing when resizing viewport
jancm
Post by jancm » Sun Jun 21, 2020 10:56 am
Attached Qcad file is freezing when trying to resize the viewport, it scales correctly but freezes.
It is also very slow, i wouldn't think it is a complicated drawing? Do I need a more robust program to do drawings with this many lines?
A004_P2_Old.dwg
(2.55 MiB) Downloaded 324 times
Re: QCAD Freezing when resizing viewport
Post by andrew » Sun Jun 21, 2020 11:28 am
Please indicate operating system, QCAD version, thanks.
Post by CVH » Sun Jun 21, 2020 12:11 pm
Open - Autozoomed its obvious there are entityies of a block 'Wall 1.0_X_Base'
@-1000000;930000 and others @ -860000,625000
That's way out and can make it dificult to render or to fit in a Viewport.
Viewing A1 Layout has a certain amount of lag but not a freeze.
Zoom until 100 <1000 and yo will notice the page with other views is there.
So, part of your drawing is out of scale to fit that.
It is surely not the amout of Entities.
Don't have an overview of What, Where, How ... Strange drawing setup.
I only tried to scale GA_T_NOTE what worked out fine.
