Using Debian with version 3.24.3.0 (3.24.3).
I'm working on a set of drawings that someone else created years ago. Trying to build PDFs off the paper space results in a few shapes not displaying on the paper space. Almost everything displays fine. How can I force these few things to display on the paper space properly? Thanks.
Paper space display mystery
- bad.dwg
- (260.69 KiB) Downloaded 330 times
- Screenshot_2020-06-18_12-42-11.png (184.07 KiB) Viewed 4323 times
- Screenshot_2020-06-18_12-43-17.png (199.47 KiB) Viewed 4323 times
Re: Paper space display mystery
Please attach drawing files, screenshots, thanks.
They are attached ...
Strange indeed.
1x Block 'Finder' displays correct.
Block reference is on Layer 0, most segments are drew on 'DRAW'
Pitty the two arc are manco. Added as individuals on 'DRAW'
Block scale of 0.75
Most lines have 'Default' width.
Block 'Finder' has a fixed text '1031CR'
The other |finders| are exploded on layer 'DRAW' and have a different text on Layer 0.
but I can't get them to display.
But I found a trick ... Select all from 'DRAW'
Make Block from selection.
Put Block reference on Layer 0
And then they display.
I originally posted without screenshots and file. Didn't notice those instructions so I updated the original post hoping it would be a non-issue.
Upon trying your suggestion, CVH, it does work. Copying my model space into another paper space layout works. Thanks for the suggestion... doesn't explain the crazy behavior at all but the new layer works at least!
This seems to be fixed in the current snapshot release (3.24.3.9).
Sounds great! Any idea specifically why the problem?
