Problems A: Roundings B: Snapping
Post by CVH » Mon Jun 08, 2020 2:32 pm
All,
Reffering to:
https://www.qcad.org/rsforum/viewtopic.php?f=8&t=7319
The rounding in this example would fail if the smaller circle is not touching the larger one.
Similar thread as with rounding polys a firm while ago.
Try it out in the attached file.
Round (RN) Trim, Radius 5
Please, avoid selecting the pointing hints.
These hints are on a locked layer.
This layer is set to 'not snappable'.
Disregardig those settings the function will snap to entities on that layer.
Round Problem.dxf
(103.44 KiB) Downloaded 34 times
Re: Problems A: Roundings B: Snapping
Post by CVH » Fri Jul 24, 2020 1:07 pm
Pictures then.
I can't get it to work.
petevick
Post by petevick » Fri Jul 24, 2020 2:37 pm
I can get it to work with 6.1 and 6.0, I picked towards the top of the smaller circle first then a point on the arc depending what the 'preview' shows. 5.9 is a no go.
Pete Vickerstaff
Linux Mint 20.0 Cinnamon, Qcad Pro 3.24.3
Post by CVH » Fri Jul 24, 2020 2:53 pm
I know, as long as the circle crosses or just touch it's OK.
That is why they are green.
This is already so long a problem.
It gets worse with polys.
To be correct, all are Arc's.
A circle needs two cuts, that is already solved by the prefix with gaps.
Intuitive one would think this is not a problem.
Just put a rounding between the two.
A CAD I used 20 years ago took the click side into account.
The rounding should obey those sides at both ends.
