All,
Reffering to:
https://www.qcad.org/rsforum/viewtopic.php?f=8&t=7319
The rounding in this example would fail if the smaller circle is not touching the larger one.
Similar thread as with rounding polys a firm while ago.
Try it out in the attached file.
Round (RN) Trim, Radius 5
Please, avoid selecting the pointing hints.
These hints are on a locked layer.
This layer is set to 'not snappable'.
Disregardig those settings the function will snap to entities on that layer.
Problems A: Roundings B: Snapping
- Round Problem.dxf
- (103.44 KiB) Downloaded 446 times
Re: Problems A: Roundings B: Snapping
Pictures then.
I can't get it to work.
- petevick
- Premier Member
I can get it to work with 6.1 and 6.0, I picked towards the top of the smaller circle first then a point on the arc depending what the 'preview' shows. 5.9 is a no go.
Pete Vickerstaff
I know, as long as the circle crosses or just touch it's OK.
That is why they are green.
This is already so long a problem.
With polylines it gets even worse.
To be correct, all are Arc's.
A circle needs two cuts, that is already solved by the prefix with gaps.
Intuitive one would think this is not a problem.
Just put a rounding between the two.
A CAD I used 20 years ago took the click side into account.
The rounding should obey those sides at both ends.
Update:
- Snapping to entities on a layer that is set not snappable seems to be fixed.
- Rounding the lower example still fails.
With this fix I hope that it is no longer required to open up the circles before rounding:
https://github.com/qcad/qcad/commit/a53 ... bc6c1d78b5
Intended for v3.28.1.3
