Crash when saving
Doug G
Crash when saving
Post by Doug G » Sun Apr 12, 2020 7:10 pm
I am new to QCAD and am having a problem when saving. Every time I try to save my work I get an error and the program shuts down. I loaded QCAD to my laptop and it seems to work fine there. Any ideas what might be causing the problem on my desktop? I am using windows 8.1
Thanks, Doug
Re: Crash when saving
Post by Husky » Sun Apr 12, 2020 7:29 pm
Hi Doug - welcome to the QCAD forum
The desktop has the same OS like the laptop?
Both are 32 oe 64 bit?
Which QCAD version you are using? Same version used on both systems?
Does it happens with all drawings or only with one particular? Only one then please attache the drawing to this topic.
If you played around with multiple QCAD installation (Trial, Pro etc.) then it is crucial that you haven't mixed different versions in the same directory. Is that given?
Doug G
Post by Doug G » Sun Apr 12, 2020 7:40 pm
My system is 64 bit and I loaded the 64 bit version of QCAD. All I did is draw a line and try to save. I also loaded a drawing that I had made in draftsight and tried to save as, same problem.
Post by Husky » Sun Apr 12, 2020 8:20 pm
0425E797-4499-4B19-9C4A-AA9D1E845D49.jpegMy system is 64 bit and I loaded the 64 bit version of QCAD. All I did is draw a line and try to save. I also loaded a drawing that I had made in draftsight and tried to save as, same problem.
Sounds good to me ...
The error message looks like it is a windows and not a QCAD issue. Unfortunately it could be triggered for many reasons.
Right now the best think what I can think of is to try to ...
... run QCAD in a compatibility mode. I can't remember anymore which options are given in Win7 but just try to run it on a Windows version which is older as Win7. Vista, XP, ME or so ..
Maybe this link helps:
https://www.howtogeek.com/howto/10436/u ... windows-7/
... the other thing would be to test the 32 bit QCAD version. Remember not to mix different version of QCAD in the same directory. Paralell installations are ok but you can't run them at the same time.
Post by andrew » Tue Apr 14, 2020 9:18 am
Please try:
- Start QCAD
- Edit > Application Preferences > File > Open/Save > File Dialog > Use system file dialog (UNcheck this preference)
- Restart QCAD
QCAD (Qt) will then use its own file dialog instead of trying to use the Windows native file dialog which might be causing the problem.
MarcW
Post by MarcW » Wed May 06, 2020 2:58 pm
I have the same problem as Doug G.
I downloaded QCAD Pro yesterday. I never had a trial or any other version. When I first tried to save a simple file it caused the program to "Not Responding". I tried andrews fix but it still will not save, save as, open any file. It does autosave though.
QCAD Pro: 3.24.3.0 64bit
Windows 8.1
System
Processor: Intel (R) Core™ i3-4160 CPU @ 3.60Hz 3.6 GHz
System Type: 64-bit Operating System, x64-based processor
Post by andrew » Wed May 06, 2020 3:09 pm
Did you also try the 32bit version?
MarcW
Post by MarcW » Wed May 06, 2020 5:02 pm
Thanks andrew.
I uninstalled the 64 bit version and installed the 32 bit version.
It appears to be saving files properly now.
