Dimensions problem
- Newbie Member
Dimensions problem
I installed now version 3.24.3 and got trouble when trying to read old files. Lines are too large. try to change line properties without success... I add a print screen.
I have a professional licence but I am not expert using this kind of products.
- Print screen 2020-04-11_121927.jpg (478.17 KiB) Viewed 5133 times
- Newbie Member
Re: Dimensions problem
Sorry. I am using Windows 10 (64 bit version).
Hi, jaime Pires
Please elaborate your problem in full.
Do you have problems with dimensions, line weigth or both?
Could you attach the file?
- Newbie Member
Hi
When opening a draw and zoom in I have problems with line weigh, as you can see in the previous attached picture. Line weight grow. Even new lines don't work. It was fine with my previous version.
- Print screen 2020-04-12.jpg (395.58 KiB) Viewed 5086 times
- Newbie Member
Look for print screen I add now. In the left what I get with licenciad product and in the right what I get with the demo
product (wich is what I expect)-
- Newbie Member
Hi. I think I fixed it. For some reason the new version come with Scale Line Type Parameters on.
So: I disable it on: Aplication preferences, Graphics view
And than, in same folder I put Default Lineweight for 0,00mm
Apparently is working.
Regards
Regards
Meaning that the entities are all drew by default weight?!
Odd fashion.
Odd fashion.
Just curious - the screenshots are not from the same computer, correct?Jaime Pires wrote: ↑Mon Apr 13, 2020 11:42 amLook for print screen I add now. In the left what I get with licenciad product and in the right what I get with the demo2020-04-13_113829.jpg product (wich is what I expect)
- Newbie Member
Hi
Screenshots are from the same computer. You have only one Screenshot with two versions side by side...
Thanks for the info. Now I'm completely confused! You are able to run two QCAD sessions/versions at the same time?Jaime Pires wrote: ↑Mon Apr 13, 2020 10:10 pmHi
