dwg2pdf -auto-orientation
zutomtech
Post by zutomtech » Tue Feb 11, 2020 12:23 pm
In change log I found this:
Command line tools:
dwg2pdf:
Add switch -auto-orientation, auto page orientation based on bounding box
In documentation dwg2pdf this new feature doesn't exist yet.
Could you give me an example how can I run dwg2pdf with this option?
Re: dwg2pdf -auto-orientation
Post by andrew » Tue Feb 25, 2020 1:31 pm
Example:
dwg2pdf -auto-orientation -o output.pdf input.dxf
