I have a problem with dwg file display on QCAD. I use version 3.24.2.0 (3.24.2) on windows 10.
Below in atachement screen from 3D-Tool viewer and QCAD. The problem was pointed in red circles.
3d-tool screen:
qcad screen:
In atachement test.dwg file which was presented above.
Regards
Tomasz
[solved] Problem with dwg file drawing in QCAD
- test.dwg
- (331.5 KiB) Downloaded 320 times
Re: Problem with dwg file drawing in QCAD
You can adjust the dimension label size under:
Edit > Drawing > Preferences > Dimension > Dimension Settings
Thank you for answer.
The problem is that I use dwg2pdf command line converter from dwg file to pdf.
How can I set dimension settings for all converted files in batch (command) mode?
Have a look at the -set switch of the dwg2dwg command line tool:
https://qcad.org/en/products/qcad-comma ... ls#dwg2dwg
Ok ... thank you.
Another question:
In change log I found this:
Could you give me an example how can I run dwg2pdf with this option?
Another question:
In documentation dwg2pdf this new feature doesn't exist yet.Command line tools:
dwg2pdf:
Add switch -auto-orientation, auto page orientation based on bounding box
Please post any new, unrelated question you might have as a new topic, thanks.
