QCAD has unexpectedly quit.
turtle
Post by turtle » Sat Jan 11, 2020 3:30 am
Greetings
I have been using qcad almost daily the past few months and its been great.
However 3.23 has been running slower than 3.22 and now crashed on me.
Here is the console output:
Warning: RPolyline::appendShape: arc or line not connected to polyline at RVector(57.9251, 67.6191, 0, true):
shape:RLine(RShape(address: "0x89d5210"), startPoint: RVector(57.9251, 67.6191, 0, true), endPoint: RVector(58.6395, 67.6191, 0, true))
gap: 0.0529179
17:39:23: Debug: autosave skipped [17:39:23]: no modifications
17:44:23: Debug: autosave skipped [17:44:23]: no modifications
17:49:23: Debug: autosave skipped [17:49:23]: no modifications
17:54:23: Debug: autosaving [17:54:23]: file: /home/turtle/thinkdoc/projects/80ST/~80ST_site-v2.dxf
17:59:23: Debug: autosaving [17:59:23]: file: /home/turtle/thinkdoc/projects/80ST/~80ST_site-v2.dxf
18:04:23: Debug: autosaving [18:04:23]: file: /home/turtle/thinkdoc/projects/80ST/~80ST_site-v2.dxf
18:09:23: Debug: autosaving [18:09:23]: file: /home/turtle/thinkdoc/projects/80ST/~80ST_site-v2.dxf
/opt/bin/qcad: line 9: 17654 Segmentation fault LD_LIBRARY_PATH="$DIR" "$binary" "[email protected]"
Please use the offscreen platform plugin for headless systems
(without a running X11 server):
/opt/bin/qcad -platform offscreen
In addition, you might have to override the default Qt style
to prevent the loading of a native desktop style (such as GTK):
/opt/bin/qcad -style plastique
dmesg output:
[Fri Jan 10 18:09:32 2020] qcad-bin[17654]: segfault at 239aec80 ip 00007fe8f23dc628 sp 00007ffefa25f6a0 error 4 in libqcadcore.so[7fe8f2228000+57c000]
[Fri Jan 10 18:09:32 2020] Code: 18 48 89 97 b8 00 00 00 88 87 c0 00 00 00 4c 89 e7 e8 ac 0b fc ff 48 8b 45 08 48 63 50 08 48 8d 5c d0 10 eb 15 0f 1f 44 00 00 <48> 8b 3b 48 83 c3 08 48 8b 17 ff 92 38 03 00 00 4c 89 e7 e8 80 0b
ldd
ldd libqcadcore.so
linux-vdso.so.1 (0x00007ffc293f6000)
libQt5PrintSupport.so.5 => /opt/qcad-3.23.0-pro-linux-x86_64/./libQt5PrintSupport.so.5 (0x00007fa92af82000)
libQt5Svg.so.5 => /opt/qcad-3.23.0-pro-linux-x86_64/./libQt5Svg.so.5 (0x00007fa92ad2f000)
libQt5Widgets.so.5 => /opt/qcad-3.23.0-pro-linux-x86_64/./libQt5Widgets.so.5 (0x00007fa92a4fe000)
libQt5Gui.so.5 => /opt/qcad-3.23.0-pro-linux-x86_64/./libQt5Gui.so.5 (0x00007fa929d63000)
libQt5Script.so.5 => /opt/qcad-3.23.0-pro-linux-x86_64/./libQt5Script.so.5 (0x00007fa9298db000)
libQt5Network.so.5 => /opt/qcad-3.23.0-pro-linux-x86_64/./libQt5Network.so.5 (0x00007fa929555000)
libQt5Core.so.5 => /opt/qcad-3.23.0-pro-linux-x86_64/./libQt5Core.so.5 (0x00007fa928e35000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fa928c14000)
libstdc++.so.6 => /usr/lib/gcc/x86_64-pc-linux-gnu/9.2.0/libstdc++.so.6 (0x00007fa92879d000)
libm.so.6 => /lib64/libm.so.6 (0x00007fa92845b000)
libgcc_s.so.1 => /usr/lib/gcc/x86_64-pc-linux-gnu/9.2.0/libgcc_s.so.1 (0x00007fa928243000)
libc.so.6 => /lib64/libc.so.6 (0x00007fa927e77000)
libGL.so.1 => /usr/lib64/libGL.so.1 (0x00007fa927c01000)
libz.so.1 => /lib64/libz.so.1 (0x00007fa9279ea000)
libicui18n.so.56 => /opt/qcad-3.23.0-pro-linux-x86_64/./libicui18n.so.56 (0x00007fa927551000)
libicuuc.so.56 => /opt/qcad-3.23.0-pro-linux-x86_64/./libicuuc.so.56 (0x00007fa927199000)
libicudata.so.56 => /opt/qcad-3.23.0-pro-linux-x86_64/./libicudata.so.56 (0x00007fa9257b6000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007fa9255b2000)
librt.so.1 => /lib64/librt.so.1 (0x00007fa9253aa000)
libgthread-2.0.so.0 => /usr/lib64/libgthread-2.0.so.0 (0x00007fa9251a8000)
libglib-2.0.so.0 => /usr/lib64/libglib-2.0.so.0 (0x00007fa924e89000)
/lib64/ld-linux-x86-64.so.2 (0x00007fa92b995000)
libglapi.so.0 => /usr/lib64/libglapi.so.0 (0x00007fa924c57000)
libdrm.so.2 => /usr/lib64/libdrm.so.2 (0x00007fa924a45000)
libX11.so.6 => /usr/lib64/libX11.so.6 (0x00007fa924708000)
libxcb-glx.so.0 => /usr/lib64/libxcb-glx.so.0 (0x00007fa9244ec000)
libxcb.so.1 => /usr/lib64/libxcb.so.1 (0x00007fa9242c2000)
libX11-xcb.so.1 => /usr/lib64/libX11-xcb.so.1 (0x00007fa9240c0000)
libxcb-dri2.so.0 => /usr/lib64/libxcb-dri2.so.0 (0x00007fa923ebb000)
libXext.so.6 => /usr/lib64/libXext.so.6 (0x00007fa923ca9000)
libXfixes.so.3 => /usr/lib64/libXfixes.so.3 (0x00007fa923aa3000)
libXdamage.so.1 => /usr/lib64/libXdamage.so.1 (0x00007fa9238a0000)
libXxf86vm.so.1 => /usr/lib64/libXxf86vm.so.1 (0x00007fa92369a000)
libxcb-dri3.so.0 => /usr/lib64/libxcb-dri3.so.0 (0x00007fa923496000)
libxcb-present.so.0 => /usr/lib64/libxcb-present.so.0 (0x00007fa923293000)
libxcb-sync.so.1 => /usr/lib64/libxcb-sync.so.1 (0x00007fa92308c000)
libxshmfence.so.1 => /usr/lib64/libxshmfence.so.1 (0x00007fa922e8a000)
libexpat.so.1 => /usr/lib64/libexpat.so.1 (0x00007fa922c5f000)
libpcre.so.1 => /lib64/libpcre.so.1 (0x00007fa9229ee000)
libXau.so.6 => /usr/lib64/libXau.so.6 (0x00007fa9227ea000)
libXdmcp.so.6 => /usr/lib64/libXdmcp.so.6 (0x00007fa9225e4000)
libbsd.so.0 => /usr/lib64/libbsd.so.0 (0x00007fa9223cd000)
Not a big deal but let me now if I can help track down the bug.
Cheers
Comments based on Version: 3.23 unless otherwise noted.
