[solved] Ver 3.24.0 Drawing area is low resolution (pixelated) on screen
[solved]Ver 3.24.0 Drawing area is low resolution (pixelated) on screen
System: Windows 10 64bit
QCAD ver: 3.24.0 professional
Problem:
After upgrading to ver 3.24.0 the drawing area appears in “low resolution” – this makes curves and text appear jagged or “pixelated” and unclear, particularly when zooming out of small details. This low resolution appearance also occurs in other parts of QCAD – example in the screen view of the “help” search results.
Corrective actions by user (unsuccessful):
Removed QCAD, rebooted, reinstalled ver 3.24.0. - Problem not fixed.
Removed QCAD and reinstalled earlier version 3.22.1.0. - Problem resolved.
Test Files:
Test.dxf
Test.dwg
Screen Views:
QCAD 3.24.0.jpg Showing low resolution of test drawing
QCAD 3.22.1.0.jpg View of same test file after re-installing older QCAD version
Many thanks for an excellent product – I hope you are able to address this unfortunate bug in the latest version.
Regards
Problem:
Test Files:
Test.dxf
Test.dwg
Screen Views:
Regards
- test.dxf
- dfx test drawing used for screenshot
- (99.52 KiB) Downloaded 381 times
- test.dwg
- dwg test drawing used for screenshot
- (17.85 KiB) Downloaded 386 times
- screenshot: test file Low resolution in ver 3.24.0
- qcad 3.24.0.JPG (156.8 KiB) Viewed 6242 times
- screenshot:test file good resolution in ver 3.22.1.0
- qcad 3.22.1.0.JPG (172.71 KiB) Viewed 6242 times
Re: Ver 3.24.0 Drawing area is low resolution (pixelated) on screen
Clearly something wrong.
3.23 is ok.
Cheers,
3.23 is ok.
Cheers,
your test drawing looks fine on my computer
JJ Win7 pro-64
JJ, if you would specify your version it could help Andrew a lot I think.
Cheers,
Cheers,
The original attachments do not give a vivid impression of how unfocused the drawing appears.
Attached her are two close-ups of the test file in version 3.22.1.0 (good) and then in 3.24.0 show better the blurred effect.
Additional information - using file>print, the output from 3.24.0 is good. Only the screen views are degraded
Regards
Regards
- Close-up of test file in 3.24.0 showing degraded lines/text
- 3.24.0.JPG (35.74 KiB) Viewed 6220 times
- Close up of test file in 3.22.1.0 showing clear lines.
- 3.22.1.0.JPG (44.59 KiB) Viewed 6220 times
Sorry, it was so obvious it was 3.24.0, win7x64
JJ Win7 pro-64
USER2019X: Are you using a high-res / retina display?
If yes, you can enable a high-res graphics display (at the cost of performance) under
Edit > Application Preferences > Graphics View > Appearance > Use full resolution for Retina Display
To further improve the smoothness of the display, you can enable anti-aliasing on the same preferences page as well.
If no, this might be a Qt bug with retina / high-res display detection.
Problem Solved!andrew wrote: ↑Wed Dec 25, 2019 9:52 pmUSER2019X: Are you using a high-res / retina display?
Have applied your recommendation for
Please accept my grateful thanks for such a super-fast helpful reply.
Further information:
There is no obvious reduction of performance using this setting.
Monitor Name: BenQ GC2870 on Intel UHD Graphics 630
Current Resolution: 1920x1080
The reference manual still has text in low resolution (see attachment) but, for me, this does not present any difficulty - so the matter is resolved.
Thanks again & best regards
- Low resolution text in reference manual.
- ref manual.JPG (101.22 KiB) Viewed 6192 times
Re: [solved] Ver 3.24.0 Drawing area is low resolution (pixelated) on screen
selecting
(as indicated elsewhere in this post) solved my low-res problem
- qcad problem.png (46.08 KiB) Viewed 222 times
