Bug with layer visibility depending on zoom?
IbBamguvos
Post by IbBamguvos » Sun Oct 06, 2019 9:04 pm
QCAD Community Edition
Version:
3.23.0.2 (3.23.0.2)
Internet:
QCAD.org
Build Date:
Sep 22 2019
Revision:
Qt Version:
5.13.1
Architecture:
x86_64
Compiler:
gcc 9.1.0
EDIT: I tried in the professional trial, works fine there, so seems to be a problem only in the community edition :-/
If I zoom in far enough, hidden layers show up normally (not hidden).
To reproduce:
- Open the attached file (two layers, with one rect each).
- zoom in a bit, hide and show layer, things work fine.
- zoom in more, hide and show layer, nothing is hidden.
See attached screenshots and dxf.
Am I doing something incorrect here, or is visibility just broken?
Here you see that the layer is hidden, but still *both* rects show up.
zoomed in, visibility *not* ok
everything visible, ok
zoomed out, visibility ok
bug.dxf
file for reproducing
(21.79 KiB) Downloaded 34 times
