Modify block attributes in properties editor
Hello, I have a issue with changing the block properties in the editor. So All the parameters I can change with tab and fill in. But selecting the attributes I can not "tab throug" the settings. So I have to select them seperate by mouse to change.... Do anyone know how to fix this so I can "tab through" and change all the text I want. Regards Peter. Rotterdam, still rainy wheater.
- 2019-10-03 Attribute changing PE dxf QCAD.jpg (50.55 KiB) Viewed 3335 times
Re: Modify block attributes in properties editor
Hello Peter77 - welcome to the QCAD forum,
https://www.qcad.org/bugtracker/index.p ... sk_id=1905
Rain? Not yet ...
I can confirm that and my hope is that it will be fixed within a different issue regarding block attributes.
Rain? Not yet ...
Ok thanks. I read also that post before and yes it's a little bit the same issue. So if it will be fixed in the future that would be great. Regards.
