Unable to save in DWG R10 file format
rstrauch
Post by rstrauch » Tue Oct 01, 2019 5:01 pm
Hi:
I'm a new Qcad user. I made my first 2D draw. No problem to save in R11 DWG format, but is impossible to save in DWG R10 format.
Unfortunately I need this format to cut the metal plate with the CNC machine.
I attach the file in R11 format.
Any help will be helpful
Ricardo
placa11.dwg
(16.33 KiB) Downloaded 358 times
Re: Unable to save in DWG R10 file format
Post by Husky » Tue Oct 01, 2019 8:30 pm
... but is impossible to save in DWG R10 format.
Yep - after testing I can confirm that. I filed a bug report.
https://www.qcad.org/bugtracker/index.p ... sk_id=1950
Thinking about a workaround ...
Is your CNC able to read dxf or svg files?
Post by andrew » Tue Oct 01, 2019 9:26 pm
I can confirm that DWG R10 and lower are not supported for writing. These will be removed from the file dialog format choice.
