Simple API addPolyline(...)
Post by CVH » Mon Sep 30, 2019 12:24 pm
Al, Andrew,
I am enhancing the Flexpainter to use local and global polyline definitions. :D
Excluding global bulging for the moment: :|
It is globally pritty the same as for splines. :P
// With a empty collector array created in the parent function
var this.collector = [];
// The orthogonal casting function collects data
// With a global polyline datastring number
var nodStringN = 0;
setting nodStringN = 0 ......N
// With a castVector from a castPoint and a castAngle
 var castVector = new RVector(castPoint.x - Math.sin(castAngle) * scaleOffset,
                              castPoint.y + Math.cos(castAngle) * scaleOffset);
case "Nods":    // Push to global polys
    // # Issue # Again, forgot why not push versus add past end ??? Array thing ...
    if (this.collector.length == nodStringN) {
        // Start a new node-string collector with this as first vertex
        this.collector[this.collector.length] = [castVector];
    else {    // Add vertex to existing node-string collector
        this.collector[nodStringN][this.collector[nodStringN].length] = castVector;
break;
Finally the global polys are casted in a parent function
// Cast global polys if any, open/closed on open/closed Forms
// this.collector is an array with 0...N arrays of RVector's
var jpn = this.collector.length;
for (var jp=0; jp<jpn; jp++) {    // Cycle through all global polys
    addPolyline(this.collector[jp], this.isTanCloObj, false);
I thought this was the harder part because of the 0...99 substrings. 8)
// we have our collector again:
// A function wide array this time:
var collector = [];
// We push an array with a vector, bulge and let relative be default:
collector.push([castVector , bulge]);  >> casting addPolyline(collector)  No go
// Lets push a new array
collector.push(new Array(castVector , bulge));  >> casting addPolyline(collector)  No go
// Lets try adding it as beyond last
collector[collector.length] = [castVector , bulge];  >> casting addPolyline(collector)  No go
collector[collector.length] = new Array(castVector , bulge);  >> casting addPolyline(collector)  No go
// Lets add round brackets
collector[collector.length] = ([castVector , bulge]);  >> casting addPolyline(collector)  No go
// The castVector is composed out two parts
collector[collector.length] = ([castVector.x , castVector.y , bulge]);  >> Correct casting
EUREKA
It seems that only X,Y or [X,Y] variants work. :oops:
I was able to trace this back to: e_geek
simple_create.js:
Line 236 catches RVector by looking at the start of the arguments.
if so it sets v0 to the first element.
Skipping the next 3 if else and ends up at line 278,
appending a vertex (v,b)
What is: ([firts element],0.0)
What is: (Rvector,bulge,0.0)
What are too many arguments.
Besides that the actual bulge is omitted working with RVector's.
My workaround is re-splitting the castVector. :idea:
Simple API addPolyline(...) fixed?
Post by CVH » Thu Oct 17, 2019 9:14 am
Andrew,
I see a 'refactor argument detection' committed at Sep 30, 2019 to simple_create.js
Is this in answer to:
viewtopic.php?t=6618
I wasn't finished testing it and I took a new look at it yesterday.
Look at the commits because the line numbering in the topic didn't matched on GitHub.
Seems you fixed it allready. :P
