AutoCAD dwg opening but not visible in QCAD 3.23
Wilson Tree Surveys
Post by Wilson Tree Surveys » Tue Aug 06, 2019 1:53 pm
Hello everyone. I'm new to the forum and I'm hoping one of you can help me.
I'm an arboricultural consultant and I use QCAD to plot trees on topographical surveys, architects drawings and site plans in dwg and dxf formats. I operate an HP Envy Notebook running Windows 10 (latest upgrade installed) on a 64bit system.
I've experienced problems opening a dwg produced by a client in AutoCAD 2020 (error message read 'File import could not be completed') so I upgraded to QCAD 3.23. The file now opens without generating an error message, the layer & block lists show that entities are present but I'm unable to see any of them. I've attempted to change the colour of some of the entities, to double click on the page layout in the block list, and to open a version of the drawing saved in an earlier format - all without success. The attachment shows a screenshot of the file as seen in QCAD and one of a pdf version showing what it should look like.
I feel that I must have a setting or preference incorrectly set but am at a loss to say which! Can anyone suggest a method by which I can open and view the file contents?
Thanks in advance.
QCAD 3.23 file not opening.pdf
(562.29 KiB) Downloaded 374 times
Re: AutoCAD dwg opening but not visible in QCAD 3.23
Post by andrew » Tue Aug 06, 2019 2:38 pm
It looks like there are some huge elements and the drawing might be tiny due to auto zooming.
If you attach the DXF / DWG file, I can tell you more.
