Win7pro/32bit
QCADpro 3.22.1.2
I especially post this in the QCAD Troubleshooting and Problems so pro users can fix this immediately.
I could report it as a bug too if prefered.
The '0x0043 CIRC1' entry of the linetypes was corrupted in coding it to CXFversion 3.
This was a full arc radius 1 at x,y 1,0. Full Arcs do not code as polylines.
Solutions:
Edit the >lhtypeshp.cxf< file in your QCAD fonts folder.
Under [0043] CIRC1 add a line with PL 1,1,1,1,-1,1,1,1,0
Save the file, the coding should be UTF-8.
If QCAD was open, reopen it.
or
Edit the >lhtypeshp.cxf< font file with QCAD.
Select the block '0x0043 CIRC1'.
Put 2 arcs radius 1 at x,y 1,0. One from 90 to 270 degrees and one from 270 to 90 degrees.
Create a polyline from segments if prefered.
Save the fontfile and restart QCAD.
For the moment I prefer to code full arcs or circles as open type polylines with two Arcs.
Feel free to use the double arc definition with A or AR (reversed) and add the next two lines instead.
A 1,0,1,90,270
A 1,0,1,270,90
Can't post the file because for now the recoding on my Win7 is done faulty.
Linetype 'Fenceline 1' corrupted by CXF upgrade
Re: Linetype 'Fenceline 1' corrupted by CXF upgrade
Thanks. I've overlooked that one. Fixed for the next snapshot.
