[solved] Linetype issue
Posted: Fri Feb 22, 2019 1:58 pm
by Nate
It is a small issue but very annoying when i click on a line it appears to be a dotted line attached is a dxf
Re: Linetype issue
Posted: Fri Feb 22, 2019 2:40 pm
by Clive
Hello Nate, welcome.
Most likely the line type is set to something dashed!
Best practice is to set up your own layers and set the line weight, line type and colour to what works for you!
Re: Linetype issue
Posted: Fri Feb 22, 2019 2:59 pm
by Nate
i had made sure it is set to continuous i have a feeling it has something to do with the application preferences menu ????
Re: Linetype issue
Posted: Fri Feb 22, 2019 9:40 pm
by Husky
... i have a feeling it has something to do with the application preferences menu ????
Hi - I assume you are right :wink:
The dxf shows nothing unusual to me - please post a screenshot with a selected entity like this one. Thanks.
Re: Linetype issue
Posted: Mon Feb 25, 2019 1:44 pm
by Nate
this is a screenshot
Re: Linetype issue
Posted: Mon Feb 25, 2019 1:49 pm
by Nate
any help how to fix this??
Re: Linetype issue
Posted: Mon Feb 25, 2019 3:27 pm
Looks like a secondary selection color is enabled under:
Edit > Application Preferences > Graphics View > Colors > Use secondary selection color
Re: Linetype issue
Posted: Mon Feb 25, 2019 4:11 pm
by Nate
Perfect Thank you Very much
