QCAD freezing
Rantanplan7
Senior Member
QCAD freezing
Post by Rantanplan7 » Wed Dec 19, 2018 5:19 pm
Hi together,
I have an old drawing from Autosketch which I would like to use in QCAD. So I have saved it in Autosketch as DWG an opened it in QCAD. As it is in many bits and pieces I tried to make a block from it, but if I do so QCAD freezes.
DCC_10_ATM.DWG
(2.31 MiB) Downloaded 382 times
I have attached the file - any ideas why? Too many elements?
Best Regards
Sven
QCAD 3.27.6.0 / Windows 11 Professional 64-bit / 16 GB RAM, i5 [email protected], SSD
(former Autosketch 10 user)
Re: QCAD freezing
Post by Husky » Wed Dec 19, 2018 7:14 pm
Yes.
Too many elements?
Yes and no. QCAD has no problems to handle this drawing but your Hardware is struggling with it. QCAD doesn't freeze but it is busy for a long time.
Tip: Open the drawing and save it under a new name. That will already reduce the file size to less than the half of the original. Open it again, search and delete duplicates and zero length entities (kind of cleaning ;)). Than try to built your block - if your hardware is still struggling - try this one .... :wink:
DCC_10_ATM_mod.DWG
(1.06 MiB) Downloaded 378 times
Rantanplan7
Senior Member
Re: QCAD freezing
Post by Rantanplan7 » Thu Dec 20, 2018 11:16 am
Thanks Husky. It is still slow on my system. Next year I get a new laptop and hopefully large files will not anymore slow QCAD a lot down.
Still a bit strange for me to understand as I cannot see a bottleneck in the taskmanager while QCAD is working on this file - there is still free RAM available, CPU cores are all not on 100% working.
However, I'm a bit surprised about this as the minimum specs from Andrew are far below my laptop. What about adding a recommended spec sheet to give anyone an idea what is needed to get a reasonable system for QCAD?
Best Regards
Sven
Re: QCAD freezing
Post by andrew » Thu Dec 20, 2018 11:21 am
System requirements depend on your drawing file complexity. QCAD will run an pretty much any reasonably modern system. However, performance will degrade on any system as the drawing gets complexer.
