Simple text rotating
dfriasb
Senior Member
Post by dfriasb » Fri Oct 26, 2018 12:22 pm
Hello all,
I'm recently using last QCAD 3.21.3.0 version. I realized text with simple text option enabled is not rotating like before, as far as I remember. Now it rotates always with its reference point as rotating point, even when it is part of a block or a group of selected entities.
Is that some kind of bug or it's going to be like this so on?
Thank you! Best regards,
David
Re: Simple text rotating
Post by andrew » Fri Oct 26, 2018 12:48 pm
I cannot reproduce this here.
- indicate the operating system you are using and the version thereof
- attach original drawing files (DXF, DWG, ...) if appropriate
- include screenshots if appropriate
dfriasb
Senior Member
Post by dfriasb » Fri Oct 26, 2018 3:15 pm
Hi again,
Here you can find the attached dxf file. I'm running QCAD 3.21.3.0 on Linux Ubuntu 18.04.
You can test selecting all entities and rotating (F5 or F6 for example). In my case some texts are not rotating properly.
Thanks,
David
text_weird_rotation.dxf
(428.34 KiB) Downloaded 403 times
Post by andrew » Fri Oct 26, 2018 3:55 pm
Here's how that file looks here after loading with QCAD 3.21.3:
Screen Shot 2018-10-26 at 15.48.52.png (35.9 KiB) Viewed 4449 times
After selecting all and pressing F6:
Screen Shot 2018-10-26 at 15.49.15.png (54.93 KiB) Viewed 4449 times
Is this the same for you? If so, that's expected behaviour.
dfriasb
Senior Member
Post by dfriasb » Wed Oct 31, 2018 6:17 pm
It only happened once with only one drawing. If I see any other strange thing I'll advice.
Thank you!
