[solved] Block partly disappears while moving
Nobody
Post by Nobody » Fri Aug 24, 2018 8:48 am
Hi everybody,
I got a problem with some blocks, while using the moving function with mouse the block partly disappears. This also happens while rotating and scaling. I can't reproduce this bug. Maybe someone can help me to understand how this occur.
I'm using QCAD Professional 3.4.6.0 and Windows 7 64 bit. Testet it also with QCAD 3.21.2 demo and its the same problem.
Greets
Test.dxf
(110.54 KiB) Downloaded 306 times
Re: Block partly disappears while moving
Post by andrew » Fri Aug 24, 2018 10:52 am
Not a bug. While moving / rotating, etc. QCAD shows a partial preview for performance reasons.
Configurable under:
Edit > Application Preferences > Graphics View > Appearance > Display and Performance > Number of preview entities
Nobody
Post by Nobody » Fri Aug 24, 2018 11:34 am
Thank you very much. Problem solved.
Greets
