hung up memory?
cescara
hung up memory?
Post by cescara » Thu Jun 07, 2018 9:33 am
Hi I'm using QCAD 3.20.1.0 with a big carthograpic drawing (51Mb) and hungs up at almost any operation (zooming, drawing, etc.) from seconds to minutes.
I've tried to hidden layers but the problem remains. any idea?
Re: hung up memory?
Post by Husky » Thu Jun 07, 2018 4:32 pm
Hello cescara - welcome to the forum.
51 MB is big for QCAD and a fast computer with plenty Memory (RAM) is needed to keep it comfortable. If you don't have the corresponding hardware it would help to get rid of parts of unnecessary drawing parts (kind of clean out) and also use the drawing mode "Draft Mode".
