Exception occured
TSG
Exception occured
Post by TSG » Wed Mar 14, 2018 8:38 am
I've a problem with a AutoCAD-file in QCAD.
After loading the drawing I cannot save it. Instead opens an error message: "Exception occurred. Entity NOT saved: 80972d6"
What can I do to find the entity 80972d6 ?
Please help.
Thomas
Re: Exception occured
Post by andrew » Wed Mar 14, 2018 9:53 am
You can select an entity based on its handle using Misc > Select > By Handle.
If you cannot identify the problem, please
- indicate the operating system you are using and the version thereof
- indicate the exact version of QCAD you are using (see Help > About or QCAD > About QCAD)
- attach original drawing files (DXF, DWG, ...) if appropriate
- include screenshots if appropriate
TSG
Post by TSG » Wed Mar 14, 2018 10:20 am
Hi Andrew,
thanks for your reply. "Misc > Select > By Handle" is what I have been looking for.
Thomas
