[solved] AutoCAD dwg files
thecurlyjen
Post by thecurlyjen » Mon Feb 12, 2018 5:38 pm
I've not been able open other people's dwg files from AutoCAD. I've double checked I'm using my Pro version (see screen capture).
Today, I've tried to open a relatively simple file. The layers list suggests that the content has loaded, but there's nothing to see when I zoom to extents.
I'm embarrassed that I'm probably overlooking something obvious, but all out of ideas.
Any suggestions very welcome. Thanks in advance,
Jen
Screenshot 2018-02-12 11.34.24.png (308.02 KiB) Viewed 3301 times
Re: AutoCAD dwg files
Post by Husky » Mon Feb 12, 2018 5:56 pm
Hi Jen,
thecurlyjen wrote:The layers list suggests that the content has loaded, but there's nothing to see when I zoom to extents.
Most likely the content is stored in a Layout Block (Block List). If not please attache the dxf/dwg to this post for further investigation. Thanks.
thecurlyjen
Post by thecurlyjen » Mon Feb 12, 2018 8:07 pm
Ah yes, there it is.
With many more blocks and variations than I'd anticipated!
Thanks again Husky,
Post by Husky » Mon Feb 12, 2018 8:17 pm
You're welcome.
