Up/Down arrow keys behavior
dfriasb
Senior Member
Post by dfriasb » Fri Dec 22, 2017 10:11 am
Hello all,
I just installed last version of QCAD Pro 19.2. So happy with new features like moving objects with keyboard arrows and with new properties of layers (printable/snapable). Thank you very much, I think all of this will be very useful for me.
I just have one question about up and down arrow keys behavior when panning the drawing. Before 19.2 I used to pan with this keys; when pressing down key, viewpoint went down. Now is the opposite; down key moves viewpoint up, and up key moves viewpoint down.
In the other hand, left/right keys behavior is just like before: viewpoint is moved left or right in the same way as the pressed key.
I attach the drawing I'm working on. I'm using QCAD Version 3.19.2.0 (3.19.2) in Linux Ubuntu 16.04.
Best regards!
David
10.dxf
(1.46 MiB) Downloaded 153 times
