Text Box dimensioning
Matfie
Post by Matfie » Mon Dec 18, 2017 9:52 pm
Hi
I came across a strange problem. I was using Autodesk Fusion 360 software for 3D modelling at work. (this is free for educational use and is fairly easy to learn). Fusion 360 has the possibility of creating drawings directly associated with the 3D model which is nice and I was using this to produce a set of instructions for students to make the product (a simple bird house, cutting lists and different views etc). Anyway, since I am somewhat fussy I didn't like the default title block which Fusion 360 was using so I learned that to change this you create a .DWG and import it. This is where QCAD comes in, since it is my DWG editor of choice.
Alas, since I'm here on the forum.. something didn't work. I've posted my query to the autodesk forum here:
https://forums.autodesk.com/t5/fusion-3 ... 83#M143776
and the gist of it seems to be that the problem text in the .DWG which is not formatted correctly does not have a dimension associated with it. I don't really know if that makes sense, since the text is the size of the text. But, it seems that AutoCAD text items have a dimension and a margin also associated with them when saved and because the drawing I produced with QCAD did not have that, then it did not show up correctly in Fusion, sigh
So. The files I used and the explanation offered are on that thread on the Autodesk forum (I could post them here directly if required) but is this a known issue, does anybody know of any workaround?
