Multi Pages settings window not working
dfriasb
Senior Member
Post by dfriasb » Fri Nov 24, 2017 4:12 pm
Hello all,
Drawing Preferences/Printing/Multi Pages settings window is not working on my computer.
I can change settings (Nr. of Pages, Margins, etc..) but this has no effect on printing preview. Even sometimes QCAD quits suddenly with no prompting when trying to Apply changes to this settings in this window, or when clicking OK.
Changes in this settings are saved in one file's session, but when I close this file and open it again, this settings are back to Default ones again (1 column, 1 row, glue margins: 10...).
Before updating to last version of QCAD it was working. I'm using now QCAD Professional version 3.19.0.0 (3.19.0) in Linux Ubuntu 16.04 OS.
Thanks! Best regards,
David
I see 2 pages in my print preview, even I applied 1 page and 0 margin
Screenshot from 2017-11-24 15-55-33.png (343.3 KiB) Viewed 2223 times
Re: Multi Pages settings window not working
Post by andrew » Fri Nov 24, 2017 4:15 pm
Please update to 3.19.1 and report back if problem persists, thanks.
dfriasb
Senior Member
Post by dfriasb » Fri Nov 24, 2017 4:47 pm
I wasn't automatically warned of this last version, even I have enabled this option in "Check for QCAD Pro Updates" window. Anyway I installed it and now this problem is not happening anymore.
Thanks again!
