DWG2PDF does not generate correct PDF files
webdada
Post by webdada » Thu Jul 06, 2017 2:00 pm
Good morning,
When I run dwg2pdf, the generated PDF file is almost blank, with a few vertical lines (my original drawing is a full floor plan).
Please advise.
Sam
C:\tools\qcad-3.17.3-pro-win64>dwg2pdf -a -f Test_Dwg.dwg
15:16:42: Debug: RDwgPlugin::init
15:16:42: Debug: RDxfPlugin::init
15:16:42: Debug: RHelpPlugin::init
15:16:42: Debug: RPolygonPlugin::init
15:16:42: Debug: RProScriptsPlugin::init
15:16:42: Debug: RTriangulationPlugin::init
15:16:43: Debug: dropped global XDATA (no value): "ASEBlockHierarchyIndexRe
ord"
Converting
to : C:/tools/qcad-3.17.3-pro-win64\Dwg.pdf
Re: DWG2PDF does not generate correct PDF files
Post by andrew » Thu Jul 06, 2017 2:04 pm
webdada wrote:When I run dwg2pdf, the generated PDF file is almost blank, with a few vertical lines (my original drawing is a full floor plan).
This can have various reasons (line color, line width, artefacts interfering with auto zoom, etc). Please attach or e-mail your drawing file, so we can help effectively, thanks.
