Svg Export: not all entities visible
Post by andrew » Wed May 10, 2017 9:25 am
From a QCAD user:
I've exported my drawing to an SVG file. In the output, not all entities are visible / exported.
Re: Svg Export: not all entities visible
Post by andrew » Wed May 10, 2017 9:26 am
This is usually caused by very thin or zero line weights.
Please make sure that all your entities / layers have a lineweight of more than 0.00. Also avoid the default lineweight for layers.
