Bad File?
Bad File?
I had a surveyor give me a dxf file (attached), as well as a pdf of the same file. Interestingly enough I cannot get either one of these files to print. I've tried exporting as pdf & svg and saving as an earlier version. I am printing to an HP T520 24 inch printer. Can anyone else get it to print ( or even export a pdf that isn't empty) and if so, can you tell me how you did it?
- 212272016.dwg
- (170.06 KiB) Downloaded 345 times
Re: Bad File?
I was able to print the file here just fine.
Most likely, you just have to adjust your scaling, etc:
viewtopic.php?f=47&t=3317
- 212272016.pdf
- (107.06 KiB) Downloaded 354 times
Re: Bad File?
Well, thank you!. I've been messing with it for hours to get it to work. I use QCAD daily, so I do understand what you were saying.
Re: Bad File?
Hello Whicked,
I noticed in your drawing that many entities are with "Z" values which will lead to more problems. "Z" Values are used in 3D drawings. I recommend to use the "Flatten Drawing to 2D" feature/tool in QCAD to eliminate all those Z settings.Well, thank you!. I've been messing with it for hours to get it to work. I use QCAD daily, so I do understand what you were saying.
