Error while writing variable Dimtxt: Can not set dimtext to that value
Post by andrew » Fri Jan 27, 2017 3:13 pm
From a QCAD user:
When saving a previously loaded drawing / new drawing, the error message "Error while writing variable Dimtxt: Can not set dimtext to that value" is displayed.
Re: Error while writing variable Dimtxt: Can not set dimtext to that value
Post by andrew » Fri Jan 27, 2017 3:15 pm
Please ensure that the text height for dimensioning is not set to zero (0):
For existing drawings:
Edit > Drawing Preferences > Dimension > Dimensioning Settings > Text height
For new drawings that are subsequently created:
Edit > Application Preferences > Defaults for New Drawings > Dimensioning Settings > Text height
