Hi folks,
Why in my files is missing some lines and curves?
when i open with AutoCAD the draw is correct (cp-AutoCAD.PNG), but in qcad the curves are missing (cp-qcad.PNG). i use version 3.16.4.
in version 3.9.7 even line dont show.
any solution?
file in attachments.
QCAD Problem
QCAD Problem
- cp-AutoCAD.PNG (96.9 KiB) Viewed 2818 times
- cp-qcad.PNG (25.48 KiB) Viewed 2818 times
- cp.dwg
- (118.56 KiB) Downloaded 262 times
Re: QCAD Problem
These arcs are not arc entities but "planar surface entities" (3D) which are not supported by QCAD (2D). The lines are actually "regions" (also 3D) which are exploded into lines when imported in QCAD.
