Multi Core Processor Usage
dfriasb
Senior Member
Post by dfriasb » Thu Dec 22, 2016 11:14 am
Hello all,
I'm working in a urban drawing plan (13 MB approx). I'm Clipping all it to Rectangle with C,L,R command, and it's taking about 10 minutes to finish.
I'm running Linux QCAD Pro 3.15.5 in a not so new PC (Dell Inspiron with Intel® Core™ i3 CPU 550 @ 3.20GHz × 4, and 4GB RAM). It has 4 cores, but I can see that QCAD is not using them in parallel, like you can see in the image. Is it correct? Is there a way to optimize my multi-core processor usage?
I attach some images and the compressed dxf file I'm working with.
Thanks!
David
001 Planol Bases CORRECTE - sense retallar del tot.dxf.tar.gz
(1.1 MiB) Downloaded 93 times
System Setting - Linux.png (53.87 KiB) Viewed 1306 times
QCAD version - Linux.png (90.42 KiB) Viewed 1306 times
QCAD clipando plano urbano.png (159.99 KiB) Viewed 1306 times
Re: Multi Core Processor Usage
Post by andrew » Thu Dec 22, 2016 11:20 am
dfriasb wrote:It has 4 cores, but I can see that QCAD is not using them in parallel, like you can see in the image. Is it correct?
Yes.
No. This is something that has to be programmed into the application. QCAD currently only uses one core.
