I just installed today the last version (3.16.0.0) of QCad Pro in a MacBook Air 13" with OS X Sierra running.
I cannot see the View toolbox, even when it looks like enabled in the menu. I cannot see dotted and dashed lines properly, like yesterday with the older version. And there is also another problem when changing an objects layer to a New Layer in Properties Toolbox: the new layer is created, but object remains in the previous layer.
I tried to change the config file .ini and also I deleted this file, bu I'm having the same problems. This is happening in all files, old ones and new ones.
Any help? Thanks a lot,
David Frías
Troubles in new 3.16.0.0 QCad-Pro version
Re: Troubles in new 3.16.0.0 QCad-Pro version
did you install the new QCad Version in an new/empty directory?
Which exact menu are you referring to? Are you looking for the View List (View > View List) perhaps? Thanks for any clarification, screenshots, etc. you can provide.dfriasb wrote:I cannot see the View toolbox, even when it looks like enabled in the menu.
Please include screenshots, drawing files, etc.dfriasb wrote:I cannot see dotted and dashed lines properly, like yesterday with the older version.
What has changed in this new version is the way how dashed lines are rendered if screen-based linetypes are being used. This change should improve precision of arcs which were often significantly off in previous versions. Again, a screenshot would be most helpful, thanks.
Thanks for your report. I can confirm this and added a bug report at:dfriasb wrote:And there is also another problem when changing an objects layer to a New Layer in Properties Toolbox: the new layer is created, but object remains in the previous layer.
http://www.qcad.org/bugtracker/index.ph ... sk_id=1513
- dfriasb
- Senior Member
Thanks Andrew for your fast reply,
I attach some screen shots here. The file name of each image explains what it is.
Thanks again,
David Frías
Thanks again,
David Frías
- 4 Page setup.png (410.04 KiB) Viewed 6456 times
- 4 Global Linetype Scale.png (358.59 KiB) Viewed 6456 times
- 4 Drawing Units.png (369.72 KiB) Viewed 6456 times
- 4 Dimension Settings.png (415.68 KiB) Viewed 6456 times
- 3c The same object zoomed looks good in paper space.png (340.93 KiB) Viewed 6456 times
- 3b The same object in Paper Space.png (346.51 KiB) Viewed 6456 times
- 3 Layer 6d Data - Linetype_Dot.png (373.64 KiB) Viewed 6456 times
- 2 Selected Object in Layer 6d.png (358.39 KiB) Viewed 6456 times
- 1 Screen-based Linetypes enabled.png (486.15 KiB) Viewed 6456 times
Thanks. I can confirm that screen-based linetypes don't work as expected for units other than mm or inch. Screen-based linetypes are currently being redesigned for improved precision (see http://www.qcad.org/rsforum/viewtopic.php?f=73&t=4566). An update will be available shortly. Meanwhile, you might want to disable screen-based linetypes or switch to the print preview to get the best rendering.
Do you have any details for your first problem ("I cannot see the View toolbox")? Thanks.
QCAD 3.16.1 is now available which fixes the issue with adding layer from selected entities and improves rendering if screen-based linetypes are being used.
- dfriasb
- Senior Member
About View Toolbar, here you have a screenshot. It's happening in all my drawings. I attach also my .ini file.
I'm running QCad in a MBAir with external display, using both displays... I had in the past some problems related with this... maybe this information can help.
- QCad View Toolbar ON but not visible.png (323.71 KiB) Viewed 6418 times
- QCAD3.ini
- (85.95 KiB) Downloaded 438 times
