[solved] Tools/Toolbox scrolling
Panchdara
Post by Panchdara » Fri Oct 07, 2016 9:54 pm
I hope this is something that is so obvious that it is intuitive -meaning I'm daft - but here goes.
The CAD Tools box, located and docked on the left of screen, does not show snap options when using the line tool. The snap tools are below the window and I can't seem to be able to scroll down.
Here are a couple of images that should show what I mean:
Best
Win 10, QCAD 3.23
Re: Tools/Toolbox scrolling
Post by Husky » Fri Oct 07, 2016 10:30 pm
whats about to play with the numbers of columns or the icon size?
Menu / Edit / Application Preferences:
Panchdara
Post by Panchdara » Fri Oct 07, 2016 10:42 pm
Cool. I had looked thru the preferences and completely missed that one. Whilst not a complete solution, it certainly solves the immediate issue. Thank you Husky, I appreciate your assistance.
Best
Win 10, QCAD 3.23
Post by Husky » Fri Oct 07, 2016 11:10 pm
You are welcome!
BTW: Meanwhile QCAD has so many tools that it could make sense to make only those tools visible which are really used on a daily base. I have EVERYTHING in the menu but cleaned out my tool bars to have an easier overview. You can do that too in the Application Preferences:
Panchdara
Post by Panchdara » Sat Oct 08, 2016 6:53 pm
Now, this is indeed what I can use. Thanks again Husky. Your assistance is most, most appreciated.
Best
Hugh
Win 10, QCAD 3.23
