How to set the size of the options toolbar
Sazhen86
Post by Sazhen86 » Wed Aug 31, 2016 5:23 am
Hi
Running version 3.15.5 on OS X I'm having problems setting the size of the options toolbar. I can't see an option to change it directly, but if I change the size of the toolbar icons, the options toolbar also changes and becomes smaller. However, when I restart qCAD, the options toolbar reverts to its original large size. How do I make it permanently small?
Re: How to set the size of the options toolbar
Post by andrew » Wed Aug 31, 2016 10:04 am
The options tool bar currently has a fixed size that cannot be permanently changed. This is to make sure that all controls are displayed correctly and working correctly.
Sazhen86
Post by Sazhen86 » Wed Aug 31, 2016 9:23 pm
That's fair enough, and explains why there's no option to change the size.
Does the fact that it changes size when I change the other toolbar's size indicate a bug?
Jef
Post by Jef » Sun May 20, 2018 11:22 am
Any changes about this? It really does not look great alongside another toolbar. And the options toolbar takes too much empty space on its own.
options toolbar size
