No hierarchical layers, no layer colors in layer list
dfriasb
Senior Member
Post by dfriasb » Thu Mar 10, 2016 1:16 pm
Hello all,
I'm user of QCAD Pro from a year ago. I used hierarchical layers, but a few days ago I decided to disable it just to see what happened with layer names and so on. The problem is that right now I don't know how to enable again them! I looked everywhere and I didn't see the option.
I have another doubt, regarding to the color of the layer. I can see in some of your screenshots that you can "preview" your layer color in the layer toolbar. I cannot, I just see the visibility, the lock/unlock icon, and the name of the layer; but not the color.
I'm using 3.12.8.0 version in OS X.
Re: Hierarchical layer list
Post by andrew » Thu Mar 10, 2016 1:30 pm
dfriasb wrote:The problem is that right now I don't know how to enable again them!
Edit > Application Preferences > Widgets > Layer List
Screen Shot 2016-03-10 at 13.22.25.png (112.24 KiB) Viewed 5531 times
You might have to restart QCAD after changing the preference.
Colors should always be visible in the layer list if you are using QCAD Professional. Could it be that you are using the free QCAD Community Edition? QCAD CE has no hierarchical layers and no colors in the layer list. You can check under QCAD > About QCAD.
As a QCAD Professional user, please make sure that you always download QCAD by clicking the download link that was sent to you via e-mail or from our online shop as described on our web site.
dfriasb
Senior Member
Re: No hierarchical layers, no layer colors in layer list
Post by dfriasb » Thu Mar 10, 2016 4:52 pm
I checked it looks like I'm using QCAD Pro version. I copy&paste text in "About QCAD Professional" window, on the QCAD Pro menu:
QCAD Professional
Version:
3.12.8.0 (3.12.8)
Internet:
QCAD.org
Build Date:
Feb 17 2016
Revision:
3f0a98c
Qt Version:
5.5.1
Architecture:
x86_64
Compiler:
Clang 7.0.2
I just downloaded last update from RibbonSoft website and tried again, but it's happening the same thing with hierarchical layers and colors in the layer tool widget.
Post by andrew » Thu Mar 10, 2016 8:06 pm
You might have to reset your configuration by deleting the file ~/.config/QCAD/QCAD3.ini as described in detail at:
viewtopic.php?f=47&t=3325
