Create library item tool
Always indicate operating system, QCAD version
Attach drawing files, screenshots
Post one question / problem per topic
J-J
Moderator
Post by J-J » Thu Dec 31, 2015 7:50 am
QCAD-64 on Win7-64
When I use the "create library item" tool, everything works alright, except that when the work screen comes back, the cursor remains in the creation mode and you need to do a right click to return to working mode. I remember that in previous releases, the tool was terminated automatically. I'm not sure if it is intended behavior, but I think the auto termination is more practical.
JJ Win7 pro-64
Re: Create library item tool
Post by andrew » Mon Jan 04, 2016 2:06 pm
