Edit Library Items and save as Same Name
stefanjacobs
Post by stefanjacobs » Wed Oct 14, 2015 11:24 am
Hi there,
When creating a library item and then deleting it in the library folder, then creating a new one with the same filename, but different size, the new one still has the properties of the old one. Even when I hit "Update DB from file system." For what it's worth - the library item is a polygon with 5 edges. The preview does update though, but when inserting it into a different drawing, the scaling is back to the first size. The workaround I found is to just give the library item a new name.
QCAD 3.10.0.0.
Stefan
