RC4 is Unstable [solved]
Retiree
Post by Retiree » Mon Mar 12, 2012 6:52 am
Running RC4 under MAC OS 10.7.3
After adding some text in several locations I got the dreaded beachball for 10 seconds then crash out. Another after big select.
These events can happen but need to be very rare.
Post by andrew » Mon Mar 12, 2012 8:38 am
Yes. This is the reason why QCAD 3 is still in RC (release candidate) stadium. Mac OS X handles events differently than other systems which causes 'random' problems. If you experience these problems, please use QCAD 2.2 (current stable release).
tukuyomi
Post by tukuyomi » Tue Mar 20, 2012 7:36 pm
I experience some instabilities on Windows XP as well.
Crashes happen randomly, so it's not easy to give you details on what was going on just before :/.
But for sure, these did not happen that frequently on RC3, nor on linux RC4.
In any case, is windows crash debug going to be useful for you?
Post by andrew » Tue Mar 20, 2012 9:19 pm
tukuyomi: thanks for the report. Crash logs are not helpful at the moment. I know what the problem is (scripts being interrupted by system events). It needs some time to fix it, but we're on it.
Re: RC4 is Unstable
Post by andrew » Mon Apr 02, 2012 2:37 pm
Please disable the script debugger and restart QCAD:
- 'QCAD Professional' - 'Preferences' - 'Scripting' - untick 'Enable Debugger'
This seems to fix or at the very least improve the situation a lot. I'm still investigating if this is really the cause though..
Re: RC4 is Unstable
Post by Husky » Tue Apr 03, 2012 7:47 am
@ Andrew - JFYI
I have the same experience like tukuyomi under XP - from time to time QCad RC4b crashed every couple minutes. I will try your hint with the Debugger. We will see what happens ...
tukuyomi
Re: RC4 is Unstable
Post by tukuyomi » Wed Apr 04, 2012 11:06 am
andrew wrote:Please disable the script debugger and restart QCAD:
Andrew, thank you for replying.
Definitely, RC4 does not crash on me anymore, for a few days now, thank you for the tip :D
Re: RC4 is Unstable
Post by andrew » Wed Apr 04, 2012 11:14 am
tukuyomi wrote:Definitely, RC4 does not crash on me anymore, for a few days now, thank you for the tip :D
Excellent! Thanks for the feedback.
Re: RC4 is Unstable
Post by Husky » Wed Apr 04, 2012 8:59 pm
tukuyomi wrote: Definitely, RC4 does not crash on me anymore, for a few days now, thank you for the tip :D
Same result with my Qcad :) Thanks Andrew!!!!
