[solved] Copy of part of a layer to a layer copies the whole layer
CerpherJoe
Post by CerpherJoe » Sun Nov 22, 2020 11:41 pm
I have two separate QCAD installs. On the first I am able to copy items from a layer in a non-QCAD DXF file into a QCAD file onto a specific layer, no problem. However, in the other installation (perhaps different application configuration?) when I copy a handful of items from a layer, QCAD seems to copy the entire layer, even creating anew that layer in the destination DXF file where it previously did not exiist.
Any ideas? Thanks!
Works ok on:
3.22.1.0 (3.22.1)
Windows 10
Having problems on:
3.22.1.0 (3.22.1)
Windows 7
Re: Copy of part of a layer to a layer copies the whole layer
Post by Husky » Sun Nov 22, 2020 11:52 pm
Hi CerpherJoe,
are the options for paste set identical in both QCAD installation? Launch paste and compare the options:
CerpherJoe
Post by CerpherJoe » Mon Nov 23, 2020 2:33 pm
Thank you Husky! The install with the issue is in a remote office, I'll report back as soon as I can check.
CerpherJoe
Re: [solved] Copy of part of a layer to a layer copies the whole layer
Post by CerpherJoe » Tue Nov 24, 2020 3:51 pm
That was it... thanks Husky!
