QCAD interactive script shell
Beyond this link
https://www.qcad.org/en/tutorial-intera ... pt-actions
Is there any link
to example with interactive script prompt
asking for a parameter and then saveing same parameter?
[QCAD 3.26.4.0 (3.26.4)
Windows 11]
Kind regards
Interactive Script shell
Re: Interactive Script shell
There are not much tutorials out there but one considers all open source scripts as fine examples.
See: https://github.com/qcad/qcad
For some simple API dialog methods see:
https://github.com/qcad/qcad/blob/55d15 ... e_input.js
Another that comes to my mind is:
https://github.com/qcad/qcad/tree/611a1 ... entWidgets
If that doesn't answer your questions then start a topic in this forum:
QCAD Programming, Script Programming and Contributing
An example code snippet of what you want to achieve may say more than words.
(Included in a code pane is preferable)
Thanks a lot CVH
