[solved] Templates appearing in model space - confused beginner
chrisv
Post by chrisv » Wed Feb 01, 2023 9:50 pm
I'm trying to produce a drawing with (for example) two Layout pages with a different view of the drawing on each. I'm happy with using Viewports and setting up new Layout blocks. However I want to use a template for each of the Layout pages and I'm confused over how this works.
If I create a new drawing with the desired samples from File->New from template... I get a new drawing with a Model space and two Layout spaces. However the Template (border, title, etc.) appears in the Model space. My understanding is that presentation elements like this are in the Layout, not the Model space, i.e. I draw in the Model space then create Viewports to produce views of the drawing in the Layout pages with the template and surrounding information. However this doesn't seem to be the way that the templates are set up - I've had a look through a few tutorials but I'm still completely confused by this. Essentially, my problem is that I expect template elements to be part of the Layout space - but they're in the Model space.
I've clearly got some fundamental misunderstanding but can't see what it is - can anyone explain how I can draw in Model space and project through to templates in Layout space? Or explain why it's not like this?
I'm on QCAD 3.27.1.0 and MacOS 12.6.2
Re: Templates appearing in model space - confused beginner
Post by Husky » Wed Feb 01, 2023 10:59 pm
Hi, yes it can be confusing until it isn't anymore ...
May I ask why you will use two templates for one drawing? Would it not make sense to use one template with two Layout pages?
I don't know which template your are trying to modify but if the source template has the border, title etc. in Model_Space then it was not primary designed to work with Viewports. It is designed to print directly out of Model_Space.
If you like/need to stick to this sample template select all entities in Model_Space, copy it to the clipboard and paste it in the designated Paper_Space. It has to be 1:1 like the real world physical paper sizes.
Yes you are right - for your case of application those entities have to be in Paper_Space. I already explained why there are not ....
To avoid further confusion about the terms: EVERYTHING in a template is considered as "template elements". No matter where they are (Model_Space, Paper_Space) or what they are (Entities, Layer, Blocks etc. etc.).
If it is still confusing to you please feel free to ask more question regarding this matter. I'll attache two screenshots (one Model_Space, one Paper_Space) of one of my templates. Please note that all layer, blocks and the two predefined Paper_Spaces are part of this template. Not the drawing itself in Model_Space. This template has all my "most likely" used parts of a drawing already set up in a "New" default drawing.
chrisv
Post by chrisv » Wed Feb 01, 2023 11:33 pm
Firstly, thanks for the prompt and comprehensive reply.
Apologies, this is my poor explanation.I should have said that I wanted to use the same template for each of two Layout pages, as you have suggested.
I'm using iso_en_a4_metric_portrait_aec - but basically any simple A4 landscape Metric template would fulfil my requirements for now.
How do I tell whether a template is designed to work with Viewports (other than simply trying it)? Is there a naming convention or something similar?
Thanks for these - your screenshots illustrate what I would have expected rather than what I get when using the iso_en_a4_metric_portrait_aec template, which at least gives me the confidence that my understanding isn't completely wrong. Can you tell me if there's a similar readily available template for metric A4 landscape?
Thanks and best wishes,
Chris
Post by Husky » Thu Feb 02, 2023 12:28 am
No, you are not completely wrong!
I assume the "iso_en_a4_metric_portrait_aec" already qualifies to be the source of your own template.
Fast forward ..
load "iso_en_a4_metric_portrait_aec.dxf"
delete block "Title block 2 (handy)"
switch all white layer to black below Menu/Misc/Layer/Make all white layer black
switch block "Revision" and "Title" to invisible
select the border in Model_Space
create Block from selection
reference absolute 0,0
name the block Border
switch block "Revision", "Title" back to visible
select everything in Model_Space
Clipboard - Cut with reference, absolute 0,0
Rename Paper_Space Layout 1 into e.g. DIN A4 Metric portrait
Select and edit this block
insert the clipboard content to absolute 0,0 - done
The Viewports are your job ... :wink:
Do the same for a Landscape Paper_Space and you are all set ... :wink:
chrisv
Post by chrisv » Thu Feb 02, 2023 6:57 pm
Thanks Husky, that's just what I needed.
Chris
chrisv
Re: [solved] Templates appearing in model space - confused beginner
Post by chrisv » Sun Feb 05, 2023 11:07 am
One more question...
I've successfully set up the layout in my drawing and can add viewports etc. now.
How do I create additional pages, i.e. duplicate the layout block to give me an additional page with border etc? I've tried Duplicate Block but it doesn't seem to actually do anything, and I presume I don't have to create another block then copy the border manually.
Chris
Post by CVH » Sun Feb 05, 2023 11:24 am
Please ask separate questions in separate topics, see the forum rules above
Duplicate Block (BY) doesn't work for layouts.
You get an error in the Command History reading:
Cannot copy model space block or layout blocks.
But there is a way around when using the PRO version ...
https://qcad.org/rsforum/viewtopic.php?t=9031
And more details on how to add it:
https://www.qcad.org/rsforum/viewtopic.php?t=9508
Remark that it duplicates a layout at that point in time with everything that is shown in the original.
Post by Husky » Sun Feb 05, 2023 8:10 pm
... and I presume I don't have to create another block then copy the border manually.
As you already know - Duplicate Block (BY) doesn't work for layouts.
And yes, right now you have to do it manually what isn't big deal!
Open Edit mode for the Paper_Space you need to copy,
make sure everything you need from this layout block is visible,
select all,
copy with reference (Absolute 0,0) into the clipboard,
Create a new layout block with "Add Layout Block" (BL),
open Edit mode for this new layout block,
insert clipboard content to absolute 0,0 - done.
