CAD library (ver. 3.27.8)
Krzysztof
Post by Krzysztof » Sat Jan 21, 2023 9:55 pm
How to create your own library. How to add machine part features to an existing library browser. How to create subdirectories for example (mechanical/bearings/ball bearings/series 02)
Re: CAD library (ver. 3.27.8)
Post by CVH » Sat Jan 21, 2023 11:25 pm
Just start a new folder under 'libraries' in the install path or the user path.
Or any place will do when you register the custom path in App.prefs. :wink:
By storing dxf files or snippets in that path or by menu Block > Create Library item (BT).
By storing items in sub-folders of the intended parent folder.
On using the Library Browser it may be required to update the database ... See lower right in the Dialog.
Post by andrew » Sun Jan 22, 2023 7:58 pm
Please refer also to our tutorial "Working with the Part Library" at:
https://www.qcad.org/en/tutorial-workin ... rt-library
Krzysztof
Re: [Solved]CAD library (ver. 3.27.8)
Post by Krzysztof » Sun Jan 22, 2023 10:38 pm
