[solved] Dimensions in feet
Lebedick
Post by Lebedick » Thu Dec 22, 2022 5:26 am
QCad Pro 3.27.8
I am trying to have my drawing's dimensions display as inches only.
Currently, if I enter , say, 62" as my line length then either check the length with "Info" or actually try to add the dimension on the drawing it shows 5' 2".
I have all settings in "Drawing Preferences" and "Application Preferences" set to inches.
I have even tried "Convert drawing unit" to convert from Feet to Inches, no go.
What am I doing wrong?
Thanx!
Re: Dimensions in feet
Post by Husky » Thu Dec 22, 2022 6:25 am
I wouldn't go that far but you get what you set ... :wink:
You may try a different Dimension Label below Drawing Preferences / Dimension / Dimension Settings / Label Format
These are your options on a 62 unit measurement ...
FYI: "Application Preferences" is meant for new drawing and a few extra QCAD settings - it has no effect on the actual drawing. Relevant for the actual drawing is only "Drawing Preferences".
Lebedick
Post by Lebedick » Thu Dec 22, 2022 6:31 am
Brilliant!!
Thank you so much.
