Drawing units change
Rgerhardt
Post by Rgerhardt » Tue Oct 25, 2022 11:39 pm
This in on my 2021 iMac.
While I was using the trial version I had my units set on 1/4". I purchased the Pro version and now the unit are decimal and I don't have the option to go back to the 1/4". What am I missing? Thank you
Also wanting to change the grid to 1/4".
Re: Drawing units change
Post by Husky » Wed Oct 26, 2022 1:29 am
For the current drawing those settings can be adjusted below Menu/Edit/Drawing Preferences
Look for:
-Dimension/Dimension Settings/Label Format
-General/Grid
-General/Drawing Unit
For new to create drawings the settings below Menu/Edit/Application Preferences will apply.
