I have 30+ different drawings that need to be printed. Is there a fast way of printing all of these drawings?
As it is now, it is a slow process trying to print all these individually.
QCAD version: 3.27.6.0 (3.27.6)
OS: Windows 10
How can I quickly print a lot of different drawings? (solved)
For those who are curious, my username is the model number of the first blue-beam laser pointer I bought.
Re: How can I quickly print a lot of different drawings?
If you are comfortable with using a command line terminal, you could convert them to PDF using the dwg2pdf command line tool and then print those PDF files or even print them directly using dwg2pdf.
You could easily wrap this in a for loop with a batch file for example to print all files in a directory.
dwg2pdf -printer -p A4 -auto-fit -auto-orientation myfile.dxf
I will give that a try. In the meantime, I will make this topic as "Solved" until I hit a dead end and need to get help.
