[solved] How can I change the visibility of an image in a layer?
XX852
Post by XX852 » Tue Sep 20, 2022 7:29 pm
I have an active layer with an image in it. At some point, I mistyped a shortcut and now the image is invisible. Only the image's border is shown, and the same applies to new images I add. It seems similar to how the visibility of dimension text can be changed to being boxes instead of numbers.
How do I change the visibility of the image back into something visible?
QCAD version: 3.27.6.0 (3.27.6)
OS: Windows 10
For those who are curious, my username is the model number of the first blue-beam laser pointer I bought.
Re: How can I change the visibility of an image in a layer?
Post by andrew » Tue Sep 20, 2022 7:55 pm
Perhaps you might have switched to draft mode:
https://qcad.org/doc/qcad/latest/refere ... /DraftMode
XX852
Post by XX852 » Tue Sep 20, 2022 8:03 pm
Thanks, that did the trick.
